Green and Energy Efficient List
topace4
| 06 Jan 2010 11:31 AM |
This may seem a little redundant given the forum, but in doing research on here I keep coming across different types of technologies and building methods. I was thinking to myself that it would be nice if I could find a list of various types of “green” or “energy efficient” construction methods.
After searching and coming up with nothing, I decided to compile a list. I was wondering if the folks on here would be able to add to the list I’ve started so I can make a master list and then post it on here for future builders. Please reply to this thread and I will add your ideas and suggestions.
Here's what I have so far:
topace4
Let's try that list again:
Framing • ICF – Insulated Concrete Form • SIP – Structural Insulated Panel
Electrical • Solar electrical (on and off grid) • Wind turbine
HVAC • Geothermal • Mini split ductless systems
Alton
Eric Anderson
| 06 Jan 2010 02:16 PM |
First of all, I think you need to redefine it as either “green” or energy efficient. Something can be one or the other, or both (or neither).
To me energy efficiency is much easier to define and less open to interpretation. The only question is how you measure it and what is it relative to. There is a regional component, a house built in Fargo ND is going to need a lot more insulation then one in Sothern Cal.
“Green” encompasses many concepts including efficiency, durability, occupant health (comfort, reduction of VOC compounds like formaldehyde reduction of disease), recycling, minimizing water usage and waste, use of renewable energy. etc. Personally I think the term should be “Good building”, not “green Building” as it covers what should be the norm in construction. I also believe what is green or good varies by locality.
So My list of good stuff is based on my climate (Connecticut) and is primarily energy efficiency based
Good stuff for energy efficiency
Design
Proper orientation for winter solar gain and natural shading and summer passive cooling
Passive solar design
Minimized exterior surface area to livable square footage
Foundation
ICF foundations Plus underslab insulation
Good drainage and waterproofing, some natural lighting if possible
Framing
Double wall stick framing
OVE framing + outsulation to prevent thermal bridging as well as insulated headers
ICF
SIP’s
Trusses with energy heels
Cellulose insulation r50 + ceilings as much as will fit in the wall, dense pack or wet spray
Alot of attention to airsealing
Windows:
South facing windows optimized for solar gain but shaded to prevent overheating in summer
Remaining windows should be maximal efficiency, casements if possible. East and west facing windows with vegetative shading or very low solar heat gain.
Daylighting through tubular skylights
HVAC
HRV or ERV set for 0.35 ACH
Passive solar gain
Solar airheater
Mod con boiler properly sized with outside air source
Quality, efficient, centrally located woodstove or masonry heater
Very quiet Bathroom fan on a timer or humidistat
Good kitchen exhaust fan over range
Mini split AC if needed SEER 15-18
Geothermal if very high efficiency
No heating or cooling ductwork outside of building envelope
Plumbing
Solar hot water heater
All plumbing centrally located and vertically stacked. Minimized run from HW tank to fixtures.
Low flow sinks
Shower with thermostatic mixing valve and low flow shower head
Exterior cooking area and shower area to prevent heat and moisture buildup in the house during the warmer months
Electrical
Proper use of Daylighting
100% fluorescent lighting internal and external
Modern efficient ceiling fans
Efficient right sized fridge/freezer, washer and dryer
Microwave and small oven
All electronics with small standby losses (IE control vampire loads)
| Think Energy CT, LLC Comprehensive Home Performance Energy Auditing |
jerkylips
| 06 Jan 2010 03:02 PM |
Posted By topace4 on 01/06/2010 11:31 AM This may seem a little redundant given the forum, but in doing research on here I keep coming across different types of technologies and building methods. I was thinking to myself that it would be nice if I could find a list of various types of “green” or “energy efficient” construction methods. After searching and coming up with nothing, I decided to compile a list. I was wondering if the folks on here would be able to add to the list I’ve started so I can make a master list and then post it on here for future builders. Please reply to this thread and I will add your ideas and suggestions. Here's what I have so far: looks like you're already getting lots of good replies. I've learned SO much since I've found this site. I feel like if we had started building before, I would have been completely in the dark (and not known it). There was something I read here a while ago that made a lot of sense to me - think of energy efficiency in terms of either conserving energy or producing energy. Insulation conserves, solar panels produce, etc. It has been mentioned many times here that in terms of cost effectiveness, you're much better off to conserve the energy you have. In other words, focus on the building envelope - insulate the foundation, prevent air infiltration, etc. Things like passive solar design don't necessarily cost anything except the planning time. The more I'm learning the more I'm trying to implement that strategy. One of my "must have's" at the start was geothermal. I'm now learning that making the right moves in terms of insulation, envelope, etc., it may not even be needed. |
The Sipper
| 06 Jan 2010 04:21 PM |
EXACTLY! Jerkylips, that's why SIPs and ICFs make so much sense, in many, if not most, situations.
| The Sipper |
robinnc
| 06 Jan 2010 09:14 PM |
eric.....maybe my brain is in a fog tonight.......but what exactly do you mean.....?
Also, nobody mentioned a wholehouse fan. I would think that would be eff and green.?
greentree
| 06 Jan 2010 09:22 PM |
Eric has the list monopoly, its very good. But of course as a critic and a resident of cold climate I would agree with Eric except:
on the solar tube (daylighting yes, but a chimney for conditioned air, hard to insulate, and another roof penetration)
the icf foundation foundation. A traditional poured with xps could also be in the running (I'm saying there are more options than just icf)
And while a "wish" list is great, it of course means nothing without great execution which I feel is the most important. A sip or icf house is great until you discover your exterior osb is rotting because the window install was botched or your inside drywall is moldy because water is entering into your icf house via window or door openings with no pans. Or your shower pan leaks and mold develops. And you know what, most people wont ever know this is happening for years; until the wall gets black spots or when the house is getting resided a worker pokes through the osb. I have repaired rot on 2 year old homes. Yea your energy bills are great but the air quality stinks because the wall or sillbox is full of stanky mold.
As always, its about the money. How low can I get my energy bills. It should be about the indoor air quality, how clean can I get the air my family breathes, THEN how low can I get my energy bills. I find it amusing at people who love how "green" and "tight" their new house is, and it's full of particle board and mdf furniture, cabinets, flooring, shelving and the like off-gassing like little invisible chemical plants into their hermatically sealed bubbles.
My line of thought is a green structure is a site designed, well designed, durable structure that will stand the test of time and through those principles energy efficiency follows suit. It is custom, not canned and it could be icf, sips, stick or a combination. My partial exterior list of durable details would be:
Exterior drainage plane; window and door beveled sill pans over membrane; proper window installation using butyl membrane with no sealant on the bottom flange; use of high quality commercial grade sealants where applicable without veering into wicked high voc content; use of high quality building gaskets; air barrier sealed and taped vertically; head flashings; proper pas roof underlayment/step flashing/kickouts; abutting roofs flashed at wall to below the soffit line (these areas are always rotted out); balanced attic venting; full width vent chutes; spaced deck ledgers w/flashing; proper clearance to grade; proper grade slope away; managed foundation drainage plane w/drain tile/bleeders/pit or daylight; correct backfill material; windows and doors with low air infiltration (good locking mechanisms); all penetrations (a/c, elec, vents, gas line, cable/tv/sat/phone, ect.) entering the building through a flashed penetration; flashing to the outer layer when using exterior foamboard; integrating all these flashings into the cladding used (kick the water out from behind the cladding out onto the cladding) Basically every item is to control moisture, and for anyone that has built a home or more knows, it's not as easy as it sounds to be that complete when construction is on a schedule and in full swing if it's anything more than a box.
maybe someone else can expound on interior items.
greentree
| 06 Jan 2010 09:23 PM |
Posted By robinnc on 01/06/2010 9:14 PM eric.....maybe my brain is in a fog tonight.......but what exactly do you mean.....?
According to some material I have comparing ventilation, wholehouse fans are generally inefficient and ineffective compared to ceiling fans and even window fans. |
Eric Anderson
| 07 Jan 2010 07:29 AM |
Robin,
this is very simple. What is the shape that has the most interior cubic feet per outside area.
Answer is a sphere. It is hard to build spheres. So we build boxes. A square box has the least surface area to interior cubic ft. Look at Typical European houses. What you see is square, 1 1/2 or 2 1/2 story boxes plus a roof. Look at what we build here, My parents house has 19 sides. It has a huge surface area to interior usable square footage.
The more complicated you build a structure, the harder it is to insulate it. Same with rooflines. A lot of these "modern" houses have very complicated rooflines. Today it is not uncommon for a house to have 15-20 different roof planes. Again this uses alot more material, shingles sheathing, trusses etc. All these intersecting rooflines are potential leak points.
Eric Anderson
| 07 Jan 2010 08:08 AM |
My comments are in Italics
TRUE You have to work hard to install these correctly. Good ones are gasketed top and bottom. I use duct mastic and then tape to seal the tubes, and calk the tube to the ceiling air barrier, then wrap the tube in r-8 fiberglass insulation Still not perfect but all in all gives quality lighting without too much heat loss
No question you can use conventional XPS insulation, ICF is just easier not necessarily better. I think the "warm n dry" works fairly well also, especialy coupled with interior insulation.
I agree with this 100% It is all the little things that make a great house. The doors, windows and deck attachment points have to be absolutely correct or the homeowner is going to get screwed down the road. Again the more complicated things are the more likely something is installed sub par.
Again I agree completely and would add a few things. Bulk water is not your friend.
On windows use a couple of small plastic wedges under the bottom flange to help any possible drainage.
Roof at least 4/12 pitch. Overhangs on all sides at least 18” Minimize intersecting rooflines when possible. Minimize roof penetrations by good design. Water and ice shield up at least 3 ft past the wall roof intersection.
Building in wet areas, all foundation drains to daylight, drains under the slab also.
For deck ledgers, It try to run them low down and bolt them to the foundation when possible. The last deck I did I used Maine deck Brackets, which have great standoff http://deckbracket.com/
I would summarize my position as build the smallest and simplest house you can so you can so you have more money to spend doing it correctly.
topace4
| 07 Jan 2010 12:11 PM |
Ok, well to get back on the topic of this thread…… Here’s the list that I have so far:
Framing • ICF – Insulated Concrete Form • SIP – Structural Insulated Panel • Aeonian Brick • Composite Building Structures • DuraSip panels with high strength and fire resistant phenolic-fiberglass laminate skins • Saebi Alternative Building System (SABS) • Double wall stick framing • OVE framing + outsulation to prevent thermal bridging as well as insulated headers • Trusses with energy heels • Cellulose insulation r50 + ceilings as much as will fit in the wall, dense pack or wet spray • A lot of attention to air sealing • Spray foam insulation • Minimized exterior surface area to livable square footage
HVAC • Geothermal • Mini split ductless systems. • HRV / Air exchanger system • Nightbreeze ventilation system • Daikin VRV Heat Pump • Passive solar gain • Solar air heater • Quality, efficient, centrally located woodstove or masonry heater • Mini split AC if needed SEER 15-18 • No heating or cooling ductwork outside of building envelope
Foundation • ICF foundations Plus underslab insulation • Good drainage and waterproofing, some natural lighting if possible
Windows • South facing windows optimized for solar gain but shaded to prevent overheating in summer • Remaining windows should be maximal efficiency, casements if possible. East and west facing windows with vegetative shading or very low solar heat gain. • Day-lighting through tubular skylights
Plumbing • Solar hot water heater • All plumbing centrally located and vertically stacked. Minimized run from HW tank to fixtures • Low flow fixtures • Shower with thermostatic mixing valve and low flow shower head • Rainwater collection system
Electrical • Proper use of day-lighting • 100% fluorescent lighting internal and external • Modern efficient ceiling fans • All electronics with small standby losses (IE control vampire loads) • Energy efficient appliances
strawpig
| 15 Jan 2010 01:38 AM |
I would say:
Use used materials where possible (www.craigslist.org) local salvage or scrap yard
Use longest lasting materials
Design for the site
Instead of 100% fluorescents I would push for LEDs (no mercury, more
efficient, last longer, We got some from these guys that are
awesome: www.hyperionled.com )
Build small Adjust your needs to be less Build a space that you would want to live in
A way to monitor how much energy you are using
Radiant Flooring
Materials from on/near site (alaskan chainsaw mills to make beams) |
The Sipper
| 15 Jan 2010 11:12 AM |
Mostly all great suggestions for building "Green". However, in my mind, one of the most important concepts is Eric Anderson's emphasis on the design concept of "minimizing the ratio of surface area to livable square footage" This is particularly important when budget is a priority consideration but one still wants to build a home that is energy efficient, sustainable, sturdy, healthy, comfortable etc (AKA "green") I've had contractors tell me that every corner that is added to the footprint of a house will add about $ 1,000, but pick a number. (It starts with the additional time to lay out the foundation, and adds labor and material every step of the way, right up though the finish steps of installing drywall and trim) (And, corners typically come in pairs) Just count the corners in most "plan book" designs, you'll probably find an average of about 24, or 20 more than are required for a square, or rectangular, footprint. |
| The Sipper |
Jere
| 15 Jan 2010 01:14 PM |
Foundation: Superior Walls - precast insulated concrete. 5000 psi concrete w/ R5 foam board. Warm, dry basement. Uses less concrete than poured wall & ICF. Additional insulation can be added between concrete studs. Drywall can go up with no additional wood framing around perimeter. Foundation can be installed year round, typically in 1 day depending on size and complexity... house can start being built the following day. |
I built my home with the help of Pierson-Gibbs Homes, "The Hands on House". They build the shell, you finish it.
www.p-ghomes.com |
Clark
| 15 Jan 2010 06:06 PM |
A couple of things I incorporated in my house for energy efficiency that I don't think were yet mentioned:
1. Miinimal window area (except where passive solar benefit dominates) 2. External rolling shutters on windows 3. Storm doors 4. Avoid "cathedral" ceilings 5. Avoid skylites 5. Flueless fireplace (electric if tightly constructed) |
lisl8166
| 18 Jan 2010 09:13 AM |
I have just joined and am learning continuously. However, so far nobody has mentioned DRAGONBOARD which seems to be a solution to everything: mold, mildew, water penetration, etc. and is produced ecologically sound. Anybody heard of it?
well_ok_then
| 23 Jan 2010 10:47 PM |
Clark, What rolling shutters did you use?
| 24 Jan 2010 09:13 AM |
Post tensioned concrete - uses less concrete and steel for the same strength.
I would say any kind of window shutters - sliding, hinged or rolling.
Zoned heating/cooling. Don't heat/cool rooms that don't have people in them.
Thermal storage to allow use of the efficient off peak power generation (vs the older generators brought online during peak periods).
Most important of all - a holistic approach that optimizes the whole thing, without wasting money on things that have little effect. |
egouin
| 24 Jan 2010 09:42 AM |
Posted By well_ok_then on 01/23/2010 10:47 PM Clark, What rolling shutters did you use?
I am curious as well. I investigated this option when I built my house, but could not find a supplier. I have triple pane krypton filled windows and they still account for more than 60% of my heat loss! My wife is so far against any inside mounted option I could find. Thanks, Ed
| http://www.GouinGreen.com<br>Superinsulated SIP/Modular House (HERS = 30)<br>GSHP w/SCW, ERV, Passive Solar, Solar HW |
309 |
309 |
