Exterior Stone Veneer over Rigid Insulation
Last Post 06 Oct 2013 10:25 AM by jonr. 2 Replies.
SurfsupUser is Offline
05 Oct 2013 05:59 PM
zone 5
1.5" polyiso
2x6 wall
I am wanting to put stone veneer up. what is the current recommended wall detail for this? is this what I can do?
drywall
2x6 filled with batt
1/2 sheathing
1-1/2 polyiso
paper
fiberglass mesh
scratchcoat
stone veneer
will the foam support the stone? I saw this for stucco but I am not sure what to do.
http://www.greenbuildingadvisor.com/sites/default/files/Water-managed%20EIFS.jpg
ICFHybridUser is Offline
05 Oct 2013 09:26 PM
It's a seismic thing. Your building code should speak to it. The problem is that without physical attachment to structure, the stone veneer wall will shake off during an earthquake, raining deadly missiles down on people.
Out here in a seismic Zone 4, we used expanded metal lath that was screwed to structure with screws and washers against the lath. When the scratchcoat is put on, the screws and lath become embedded, providing solid fixation. Apparently the bond between the scratchcoat and the veneer is adequate, but I did note that when the veneer went higher than 8 feet, the mason also embedded brick ties, also screwed to structure, that became part of the veneer layer as the stone was set.
Be aware that code thinks about stone veneer differently when the weight per square foot goes over a certain amount.  So, regular stone veneer might get one treatment while thin stone veneer might not require the same.
We also used a brillo pad type roll product that went up against the ICF or the wood sheathing and provides an air space behind the scratchcoat.
Investigate a rain gap, perhaps a double layer of stucco wrap. And of course tape up the sheathing or polyiso to get a good air seal.
People Online People Online: Visitors Visitors: 388 Members Members: 0 Total Total: 388
