Wood in Garage Floor
Last Post 03 Feb 2018 05:24 PM by arkie6. 6 Replies.
jloyd2323User is Offline
02 Feb 2018 01:14 AM
I am purchasing a new home and when inspecting saw wood at the surface of the concrete floor in the garage. It looks possibly like debris and one looks like it could have been used to hold something during the poor. I am concerned the wood will rot and cause me issues long term. Thought from anyone that knows about this would be appreciated.
02 Feb 2018 04:26 PM
Wood that's exposed to the garage air will take a long time to rot unless it's begin constantly re-wetted. Assuming there is a vapor barrier under the slab, painting or sealing the garage floor with the appropriate products would extend the time before the embedded wood becomes compromised.
02 Feb 2018 05:27 PM
Thank you so much for your feedback. I tied to add pictures but the reply box will not allow me. So this is new construction and you would be OK with buying it like it is?
ICFHybridUser is Offline
02 Feb 2018 07:50 PM
If you need a more robust posting, you should be able to use the "Add Reply" button to get a full range of posting features. The 'Quick Reply' is for just that.
03 Feb 2018 06:31 AM
Sounds like it's a track builder. It would be better if you can somehow post pics. To me, it doesn't make sense.
03 Feb 2018 05:02 PM
Hope this helps. Let me know what you think.
arkie6User is Offline
If it is cedar or treated lumber, it shouldn't be an issue. What size piece of lumber are we talking about here? It is not uncommon to find a treated 1x4 imbedded in the concrete to act as a screed and control joint. With this you would see a 3/4" wide board spanning the entire slab at that point.  A common place to find this embedded 1x4 would be at the garage doors and spanning the width of the garage door.  This is done when you have a break in level/slope and are doing the entire pour at the same time, i.e. the garage floor is +/- level but the apron in front of the garage has a slope away from the garage.
People Online People Online: Visitors Visitors: 126 Members Members: 0 Total Total: 126
