Posted By CTwith3 on 10 Oct 2018 02:59 PM
I filled the cracks with their concrete plug product and painted over those plug-ups with Dry Lok and their has been no leaks from those spots.
So I should put rigid insulation over the tops of blocks that have openings as that will make a difference?
My new humidifier is keeping my basement at 40%, but I’m not enjoying paid to run it all day every day.
There's no good reason to keep the basement at 40% RH. Holding the line at 60% is sufficient for keeping mold and "musty basement" smells under control.
The biggest source of moisture in most basements in summer in CT is air-leakage from the outdoors, not ground moisture coming through the foundation. When outdoor dew points are 65-70F the moisture in the outdoor air gets taken up by the slab and items near the floor that are below that temperature as adsorbed moisture. A cardboard box resting on a 55-60F slab is very likely to grow mold.
It's customary to air-seal and insulate the top of the foundation, so if there's a ledge with the open (or even closed-up) cores of the CMU peeking at you, that's both an air & moisture leak. Ideally there would be a good capillary break between the foundation and moisture-susceptible foundation sill such as metal flashing or an EPDM sill gasket. CMU and poured concrete wick moisture fairly strongly. If the foundation is wet, sealing it up completely with an impermeable foam board it could raise the moisture content of the foundation sill & band joist to troublesome levels. Buy a 2-pronged wood moisture meter and measure it. If it's 20% moisture content or higher it's time to consider jacking up the house a hair and slipping some EPDM under the foundation sill. If it's under 10% go ahead and install foam board on the top of the ledge.
