I am working on finishing my basement in my 1956 brick and block house in Zone 5 northern Illinois.
I was doing some research on insulating between the joists (no rim joists on brick and block) and was led to this forum through this
thread which had some of the information that I was looking for, but unfortunately a few broken links.
I am facing roughly the same dilemma of that OP except the upstairs walls of my brick and block house are insulated (approx. 1.5in paper-faced fiberglass?) and the wall cavities from upstairs are not open to the basement (as far as I can tell).
The joist area and approximately the top 16in of my basement walls are brick and are above grade. The lower portion of the wall that is below grade is poured concrete.
My only moisture issues are where the brick mortar meets the top of the concrete wall which will be addressed by a masonry professional. The previous owner had used waterproofing paint on approximately 50% of the walls. I had planned to apply Drylok paint to the rest just to be safe (and to keep my OCD happy). I then planned to install 2in XPS between the joists and against the brick. This would bring the areas with brick to be flush with the concrete walls below and then I planned to use 1in XPS floor to ceiling around the entire basement and finish off with insulated stud walls.
My main concern (along with the OP in the other thread) is moisture around the rim joists. If I seal this area with the Drylok and XPS, am I risking driving the moisture from the brick into the joists? The joists appear to be sitting directly on the brick with nothing in between. Also, any gaps between the joists and brick - should I seal them to prevent cold air from coming through and condensing on the warm joists?
I think the closed cell spray foam might be my solution here but I did not follow the application in the other thread completely and the link to the pictures are broken.
Any help or advice would be greatly appreciated. I am relatively new to renovations but I am doing my best to learn all I can and most importantly, to do things right the first time. This will not be my forever home but I want to make sure that it can be for whoever is next in line. I've attached some pictures that can hopefully clarify my question.
[IMG]http://i64.tinypic.com/2kowtd.jpg[/IMG]
[IMG]http://i64.tinypic.com/29w62r5.jpg[/IMG]
[IMG]http://i65.tinypic.com/auzdyd.jpg[/IMG]
