Hi, I'm a residential framer and about to replace all my windows and doors. I want to properly flash them, and have looked at both:
http://www.youtube.com/watch?v=vaKXqFtHAss&NR=1
Carl Hagstrom's flex wrap video
and
http://www.finehomebuilding.com/how-to/install-replacement-windows-and-flashing-correctly.aspx
Fine Homebuilding's article
Typically we add 3/8 shims beneath the side jambs, and dividers of windows we install at work. This creates a gap for using low-expanding spray foam. However in both of the above demos, they don't seem to shim the bottom at all - it just sits on the bevelled siding sill pan. How would you insulate the bottom this way? |
