What would be the cheapest and easiest way to temporarily heat my garage floor (pex lines are run)
Last Post 06 Dec 2013 05:19 PM by Bob I. 6 Replies.
ahrenoUser is Offline
06 Dec 2013 01:18 AM
So, i'm rebuilding my shop and i ran water lines in the slab for radiant heating. It's freezing here right now so i was wondering if anyone could recommend a cheap way to get this going. I plan to research and figure out the right way to set it up but i dont have thousands to spend on a boiler right now. If all it takes is a $200 propane water heater and a $30 recirc pump it'd be well worth it (as opposed to going out and buying some sort of other heater) i can empty it regularily to limit the risk of that one disease... having no heat out there limits my ability to work
ICFHybridUser is Offline
06 Dec 2013 10:12 AM
You haven't told us what the heating needs of the garage are.
06 Dec 2013 12:18 PM
What do I need to tell you? Its pex w/ barrier in the slab. Outside temp is currently 10-15°f which is as cold admit ever gets in Eugene, or 97402. Id like to bring the heat up any amount so I can get back to working. 50° would be awesome. 70° is awesome but probably dreaming. What more info should I provide?
Bob IUser is Offline
06 Dec 2013 12:44 PM
Is the floor insulated under the PEX and insulated from the foundation walls? (so you're not heating the ground under and around the shop) Frankly I wouldn't put water in the system until it can be permanently heated, although you might be able to use it with an antifreeze solution(?) If you can do that, hook it up to a dedicated water heater, making sure that the antifreeze solution is compatible with all components.
06 Dec 2013 12:55 PM
Most shops aren't used 24x7, so a slow changing concrete slab wouldn't be my first choice. Consider an overhead radiant heater.
FBBPUser is Offline
06 Dec 2013 02:44 PM
Posted By Bob I on 06 Dec 2013 12:44 PM
You can't use glycol in an open flame water heater. Fire hazard.
so buy an electric water heater.
