I'm looking for an experienced ICF installer for a job in NE Alabama. Located in Henagar, AL. Off exit 231 on I59. Due East of Huntsville close to GA line.
2000 sf house on full basement w/drive under garage. Structure is a simple rectangle 50' wide X 40' deep. Basement to have 600 sq ft garage and 1400 +- conditioned. Long axis sets back into hill.
Openings "all in front wall": -Double garage door -Two windows -One door
Basic gable SIP home above. Not engineered yet so please give cost options for wall thickness (6" or 8")
-Need 8' ceiling - Truss floor system to set on top of ICF's.
Need sub to do bid on the following: - provide all materials, labor, heavy equipment and bracing etc - Excavation (estimate mid range) 9% +- slope, 7 feet rise over the 40 feet. - dig and install footers, - install and pour ICF walls - four girder pockets total - pour slab inside walls, sloping garage area to door - install french drains around foundation - waterproof exterior - back fill after floor system installed
Interested subs send e-mail to john at panelstar (dot) com
