Posted By s123 on 19 Jul 2012 12:50 PM
Thank you for your thoughts. I was leaning toward building on a slab for 3 reasons:
1. money saved
2. I was told it was cooler (but if Lbear is correct, maybe it's not)
3. We have a basement (ICF) now and don't use it at all. I don't want to pay so much more for something we don't use.
That said, I'm trying to understand if ICF (above grade) works better with a basement, a slab, or crawl space (or other - like FPSF????? not sure what that is) OR if it makes absolutely no difference.
Basements are common in areas where they frost line is over 2 feet in depth. In areas where the frost line is say 48", it would make sense to do a basement since you are digging 48" to place your footings, plus they use basements to make running the plumbing lines easier. Basements provide storage and shelter during a tornado.
Having lived in homes that had basements, walk-out basements, and slab on grade I would have to say I prefer slab on grade. In all the homes that had basements and walk out basements, they ALL LEAKED when it rained heavily. The other issue is that they all had sump pumps and when the power went out during a storm, the water filled the basin and flooded the basements. I never used the basements other than for storage, which they tended to be somewhat humid and damp, which is bad for storage.
Unless I lived in tornado alley or in a really cold climate area, I would build with slab on grade. Here in AZ the frost line is 18" so doing a slab is easy and 95% of the homes are slab on grade. Some people love basements and even finish them off and live in them or make them theater rooms.
I don't believe it makes a difference, energy wise with ICF walls if you have a basement or slab on grade. Now with crawl spaces you should insulate that because it is open to the exterior air. I am NOT a fan of crawl spaces because it is just a haven for rodents, black widows, rattlesnakes, scorpions, centipedes and every other creepy crawling thing the Arizona desert has.
