Pour Video shot by a drone/GoPro
Last Post 09 Jan 2015 11:16 AM by Eldon Howe. 77 Replies.
Page 4 of 4 << < 1234
sailawayrbUser is Offline
30 Sep 2014 10:34 AM
Good to hear and know Smartwall.
If concrete buildings/structures are designed/constructed to the right structural specification and maintain their structural strength to this specification, all will be very well and they will last for centuries. However, there have been several spectacular failures of concrete buildings/structures involving rebar that failed from corrosion, so it isn’t just Helix that one needs to be concerned about.
We use basalt rebar for many of our water work projects where corrision is a high risk (e.g., small dams, fish screen by-pass tanks, hydro turbine concrete cases, etc). One really just needs to use the right product for the given application. Most buildings shouldn't have a corrosion risk and we expect that Helix will prove to be great for this application.
However, parking garages and bridges are another matter...
Eldon HoweUser is Offline
23 Dec 2014 12:31 PM
Vibrators are not always necessary, but you should have on on the walk boards ready at all times.
We use a 1.5” oztec in most pours.
Here is a You tube link of a 12"/12" pitched ICF roof where we used this vibrator.
http://YouTube/qqIDK6P2TXU
You can turn down the sound on this video.
23 Dec 2014 07:24 PM
The link doesn't work.
23 Dec 2014 08:05 PM
Posted By Eldon Howe on 23 Dec 2014 12:31 PM
What slump & psi do you use?
23 Dec 2014 08:15 PM
Oh boy...here we go again...
24 Dec 2014 03:30 PM
This link should work. It came directly off the You tube video.
http://youtu.be/qqIDK6P2TXU
These ICF roofs are engineered so we adhere to the specifications.
The roof in the video was a 7” slump with water reducer added not water to 4,000 psi concrete with Helix for crack control.
We have used other mixes as well.
I posted this because of the question about sloped ICF roofs and vibrators.
I know most ICF builders are not on board with this technique of building concrete roofs yet, Just as most wood frame builders knock ICF. Hopefully we all can move forward and build even better structures.
woulfccUser is Offline
24 Dec 2014 07:23 PM
Awesome  Eldon just assume....
27 Dec 2014 12:06 PM
Beautiful structure. I was surprised at how light the bracing system seemed to be under the roof during the pour. So how does the underside of the roof get finished out? Do those steel joists get covered with sheetrock, and does anything happen in that space, like just the usual ductwork, wiring, et cetera?
billnaegeliUser is Offline
27 Dec 2014 12:29 PM
Hi Eldon,
great vid worked fine for me, what was the core thickness, IntegraSpec has 4", 5" or 6" core?
we need to do more of this type of structure, just makes sense with ICF Walls, the SpeedFloor joists was a masterpiece idea with IntegraSpec...master piece from the master! haha great job!
talk soon, Happy New Year!
GNP Inc
ICF Construction & Concrete Services
1-800-713-7663
27 Dec 2014 12:36 PM
In this house we used Speed Floor Joist. You could also use Hambro Etc.
In between the joist is a removable steel Lock bar that secures each joist and becomes the shoring for the bottom side of the ICF. No additional shoring is needed. After the placement of concrete the lock bars are removed and wood or metal furring strips are attached to the speed floor joist and drywall is screwed on.
The space can be used for utilitys.
27 Dec 2014 12:48 PM
Posted By Eldon Howe on 24 Dec 2014 03:30 PM
Looks like a very windy location, great location for a concrete home, it should be very quite with the concrete walls and roof.
What is the price of an ICF roof?
Typically here in the US, depending on market area, the cost of ICF walls per square foot (including doors and windows) runs in the $12-$15 range. From what I read, concrete ICF roofs run in the $23-$27 range. This is OTD pricing (forms, labor, shoring, rebar, concrete, etc).
28 Dec 2014 12:04 PM
That's what I always hear/read, that ICF roofs are so expensive that they are never even considered. But I don't really get why they should be that much more expensive than ICF walls.
28 Dec 2014 01:31 PM
I would guess the steel used in the forms and the shoring needed.
29 Dec 2014 03:29 PM
That's Right, a 4" ICF form is used. so 12.00 to 15.00 or so for the ICF cost, remember this is not on a deck but up in the air. The remainder of the cost will be for a center beam, be it concrete or I beam and the speed floor/ hambro joist and installation.
The steel joist span from Concrete wall to the center beam at the roof ridge. No additional shoring is needed other than the lock bars.
30 Dec 2014 07:50 PM
Are you saying that the price of an ICF roof 'includes' all of the steel to hold it up? Like I beams?
07 Jan 2015 06:07 PM
Cost to build a total icf roof $23.00 to $27.00 per square feet is usually just the roof. But if a short span center ridge beam is used then yea. The steel I beams used in the video were both over 30' long, so the I beams were additional cost.
07 Jan 2015 07:24 PM
Posted By Eldon Howe on 07 Jan 2015 06:07 PM
...the I beams were additional cost...
They looked like C-joists to me, were they really I-beams?
The ridge beam in the video is a steel I beam.
The steel rafters are "Speed floor" composite floor joist. Speed floor joist have a S bend on the top of the joist and a triangle bend on the bottom of the joist. The S bend on the top of the joist is cast into the 4" concrete roof and the triangle bend on the bottom is used for attaching the ceiling to.
People Online People Online: Visitors Visitors: 304 Members Members: 0 Total Total: 304
