Eastern AL: seeking foundation contractor with ICF experience
Last Post 17 Jul 2020 07:20 PM by PolycreteStructures. 10 Replies.
Author Messages Informative
ubf7788User is Offline
13 May 2020 10:26 PM
Hello everyone. I hope it's ok to make a post like this. We have about 100 cubic yards of footings to pour in eastern AL for an ICF basement project. I'm hoping to find someone who has some ICF experience just because that seems to be a plus when installing footings. Thanks
smartwallUser is Offline
13 May 2020 11:45 PM
The one thing you want to do is make sure your dowels don't interfere with the webs on the block you will be using. It's good to have some corners and straights on the job at the time of your footing pour and lay them on the wet footing , then drop you dowels in and do a run from there.
14 May 2020 12:10 PM
Thanks. So the only thing the footing installer should be aware of as far as ICF is the dowel placement, is that correct? We won't have any forms on site, but the design is simple enough that we should be able to calculate the proper locations of the dowels.
14 May 2020 12:59 PM
You can do a layout on the edge of the footer if you know what block you will be using. I can't tell you how many times I've showed up at a build and some of the dowels are in the wrong place. Having a corner and a straight block makes it quicker and full proof. Of course as I've posted many times here, since 2004 I only do mono pours. It cuts out all the questions of miss placed dowels.
arkie6User is Offline
15 May 2020 04:20 PM
Posted By ubf7788 on 14 May 2020 12:10 PM
And remember not to install any dowels in door openings!  Otherwise, you will just have to cut them off later.
Here is a photo of my ICF footing right after we completed concrete placement:
https://www.fab-form.com/images/fastfoot/alanSmith/smithOverview.jpg
There are other footing examples here as well:
https://www.fab-form.com/fastfoot/fastfootOverview.php
15 May 2020 06:07 PM
Posted By smartwall on 14 May 2020 12:59 PM
Alright, I'll see about just marking dowel placement, and maybe this will be enough instead of seeking someone who specifically has ICF experience. By mono pour do you mean pouring the footings and the walls in the same pour, so no cold joint? Does this mean you pour the footings then place the wall forms immediately after?
15 May 2020 06:08 PM
Posted By arkie6 on 15 May 2020 04:20 PM
15 May 2020 09:53 PM
That's called wet setting, when you start building on fresh footings. No I pour the footing and wall in one step.
16 May 2020 01:37 PM
Smartwall, What is your territory for building with ICF? Just curious.
16 May 2020 01:54 PM
Upstate NY
PolycreteStructuresUser is Offline
If you're still looking for an installer, please PM me your contact info. We have a crew in AL. Thanks,
People Online People Online: Visitors Visitors: 174 Members Members: 0 Total Total: 174
