Stucco on Sips
Last Post 07 Aug 2007 06:01 PM by Dennis Nelson. 3 Replies.
olpjebUser is Offline
25 Jun 2007 12:55 PM
I am looking to finish my Timberframe / SIP home with traditional stucco (NOT synthetic).  My panel manufacturer has recommended traditional 30# asphalt felt paper as an exterior moisture barrier before applying the stucco.  I believe the stucco contractor uses another product.  Does anyone have any thoughts on the use of stucco on a SIP structure and the appropriate moisture barrier?
The house will be at 8800' feet elevation in S. Colorado.  The climate is particularly dry, and snowfall is variable (maybe 100" per year).
mmacgowaUser is Offline
25 Jun 2007 05:08 PM
Felt paper has been around the block and is probably the most cost effective barrier. I would check with your building department to see what they require. Around here they require the corrugated house wrap or the felt. Check also with the supplier of the stucco. Your warranty of the product will probably be effected by the wrap. I like the elastomeric Sto stucco and they recommend a paintlike barrier.
cboydellUser is Offline
29 Jun 2007 03:39 PM
We've had hundred of customer aplly stucco to our SIP's (including my own home). felt paper works fine. The other products generally fall under the category of 'vapor barriers' and will do the same job just fine too. Remember, your stucco is not adhearing to this layer anyway, but to the foam and chicken wire.
Craig Boydell
KC Panels
www.kcpanels.com
Dennis NelsonUser is Offline
Talk with your panel rep on stucco applications also. Some manufacturers will only continue warranty if specific brands or approved installers are used.
Also double check your moisture levels before applying.
I've heard nightmares of tearing down or repairing the stucco because of a 'poor install' or applying during higher moisture levels.
Dennis
People Online People Online: Visitors Visitors: 205 Members Members: 0 Total Total: 205
