With metal SIPS you can do Balloon framing. Basically one vertical member from bottom to top plate. The floor is then fastened in place with a C-channel next to the sip panel/floor edge using long sip bolts. The sip bolts run from outside, through the sip panel and into the backside of the C-channel (Trufast is one manufacturer). I did two balloon frame floors (attic and second). These photos show the attic floor.
