Floor to Sip Attachemnt
Last Post 06 Feb 2013 08:40 AM by Torben. 4 Replies.
BrianUser is Offline
05 Feb 2013 05:19 PM
Im wondering how SIPs and Floors attached. Im talking about metal claded sips here. I know that in a normal stick frame home the floors sit on the plate of the top of the wall below them... How does this work with sips?
$50/hr if I do it, $75/hr if you watch, $100/hr if you help!
05 Feb 2013 07:54 PM
The metal skin, polyurethane core SIPs that I have used do not sit on a wood floor.  The manufacturer insisted that their SIPs sit in a galvanized C-channel either on a foundation wall or footer.  Metal C-channels were also used to cap the SIPs (top plate).  Hex-head screws were used to attach the SIP to the C-channel.  The framing was more like balloon framing than platform framing.  In other words, a two storey home could be built with tall SIPs and then the floor installed.
Metal skin, polyurethane filled SIPs made on a continuous line can be quite long.  Some companies offer lengths up to 50' +.  Other companies maximum length might be only 12'.  A tall wall can be made with 12' long SIPs but the engineer may prefer that the horizontal joints be staggered so a weakened plane will not be created.
TorbenUser is Offline
06 Feb 2013 08:02 AM
With metal SIPS you can do Balloon framing.  Basically one vertical member from bottom to top plate.  The floor is then fastened in place with a C-channel next to the sip panel/floor edge using long sip bolts.  The sip bolts run from outside, through the sip panel and into the backside of the C-channel (Trufast is one manufacturer).  I did two balloon frame floors (attic and second).  These photos show the attic floor.
rnortmanUser is Offline
06 Feb 2013 08:20 AM
Torben,
Are those EPS or PU SIPs?  How long ago was that built?
I used PU Sips, the plant is only about 30 miles from the site.  I did the shell in March/April of 2011.  Placing the walls then attic floor gave me a platform for installing the roof (and the ridge wall to support the roof).  After that I installed the second floor.
People Online People Online: Visitors Visitors: 307 Members Members: 0 Total Total: 307
