Wiring in SIPs
Last Post 22 Jun 2016 12:24 PM by eweingarden. 5 Replies.
eweingardenUser is Offline
22 Jun 2016 09:46 AM
I've read what I can find and watched YouTubes, but I don't quite understand running wires in SIPs. 1. If there aren't any vertical channels, how do you get the wire from the basement up to the horizontal channel for outlets? 2. Once the wire is in the horizontal channel, do you push it (or pull it) to the end of the run, and then pull out some excess at each outlet opening? 3. With no vertical channels, how do you get wires up the panels for switches? I've seen the technique of dropping a hot ball bearing down to create a channel, but I'm looking for a different method. 4. The SIPs I am considering don't have horizontal channels at switch height. What are the drawbacks of not having those channels? 5. How do you get wires to the second floor? 6. I have the option of having drywall installed prior to the panels going up. Will having the drywall on make doing the cutouts significantly more difficult? Thanks
DavidBrownEnterprisesUser is Offline
22 Jun 2016 10:16 AM
Here is a video that shows installation of steel SIPs. If you forward to 14:43, you will see how the electrical wire is run on the inside of the wall panel alongside steel hat channel that has been screwed to the inside of the panel. The drywall will be screwed to this hat channel. So, this allows the space for the wiring to run through the walls.
22 Jun 2016 10:18 AM
Here is the correct url: https://youtu.be/YG5POO4EwMQ
22 Jun 2016 12:12 PM
Posted By DavidBrownEnterprises on 22 Jun 2016 10:18 AM
Hey thats me in the video
22 Jun 2016 12:17 PM
Posted By eweingarden on 22 Jun 2016 09:46 AM
You have to have the vertical chases in OSB SIPs to go floor to floor or to wall/ ceiling fixtures, an electrician that had done several OSB SIP houses for me "likened" the job to the same as a remodeling job with all the wire fishing
Thanks for the YouTube link. I hadn't thought of furring out the inner wall surfaces but it's something to consider.
People Online People Online: Visitors Visitors: 244 Members Members: 0 Total Total: 244
