Wood is no good!
Last Post 16 Feb 2009 07:46 AM by boettg33. 81 Replies.
Donnerwetter
| 14 Jan 2009 12:58 PM |
...Lumber is a very green product...as long as it remains in our forests, parks and backyards - with leaves on them - providing us with fruit, shade and O2...
After all...if one were to indroduce a new building product for load bearing exterior walls with the following characteristics a.) When it gets wet...it whorps, b.) burns very well and c.) is the main diet for termites?...would one really want to us this product as the main product in an exterior loadbearing wall??? |
ICFconstruction
| 15 Jan 2009 06:59 AM |
Well said Donner.
It is not that logging is the bad thing that some people say. Trees are farmed and cut over areas with young new growth supports more wildlife. I see this first hand as we own northern MN forest.
The point is wood is for furniture and trim. |
malibud
| 15 Jan 2009 11:30 AM |
I like the idea of SIPs but the cost is no where near 2-5 % higher than stick for a 1500 sqf crawl space it was 23000 $ I dug and built a basement w/ block for less. At 125 $ a yard plus pumping concrete is exspensive. Digging, heating and transportation of it takes away from its green aspects . |
ICFconstruction
| 15 Jan 2009 12:07 PM |
Malibud,
CMUs are made of concrete, and must be transported. CMUs also have little tensile strength and no insulation. How about the extra carbon your house pumps out? And that it is weak by comparison?
I started ICF Construction before I ever hear the term "green" because it is the overall best method of construction, by far. As did this website, started as an ICF forum. So forget about the "green" that is highly subjective.
And the basis for my statements comes from 14 years full-time construction consulting, primarily consisting of assessing damage to structures after catastrophe losses. Between 8,000-10,000 during that time. Currently I have an ongoing consulting gig involving minor mold to a wood framed house that resulted in a $340,000 judgement against the seller, that acted as her own GC. |
aardvarcus
| 15 Jan 2009 01:23 PM |
A reinforced concrete wall is stronger than a properly built wood wall. A properly built wood wall is cheaper than a reinforced concrete wall. Both can be insulated to identical levels. Take two almost identical homes, both properly built. One house built with properly installed ICF and one house built with with a properly installed 2*6 wall, including typical corner bracing and with plywood double diaphragm. Both houses will be using an identical foundation, roof structure, and roof tie down system. In a storm, with both homes properly designed, the first point of failure is going to be the roof. This might not be the case in a piece of junk house, but for a well designed one, it will be the case. The stresses on the roof are going to well exceed the stresses on the wall systems, and will cause the failure of the roof system, which will collapse. So now you have two houses without roofs. I admit, if the wind picks up even more, the wood walls will blow away before the concrete ones, but how much money is that really worth? You are still in a storm with no roof over your head! I could design a wall system made out of foot thick solid titanium, but what good will that be if my roof blows off? Design a version of an ICF that can be adapted for roof use, and then you will be talking, but until then, using concrete in your walls will not magically make your roof stronger. It will make your walls stronger, but if they are strong enough to begin with, what does it matter? I have seen horribly built homes that the walls might be the first thing to fail, but that doesn’t mean they need to upgrade to concrete, it means they need to learn how to use the material they have correctly. That being said, if you wish to spend your extra money reinforcing a part of your home, don't let me discourage you. It is a much better investment than $18 per square foot wood flooring, $1000 speaker cables, or other such nonsense people like to waste their money on. If you will sleep more soundly knowing there is concrete in your walls, then by all means go for it. As for me, I will spend my extra money on the roof structure. If I ever reinforce my roof to the point my walls are the weakest link, I will worry about my walls. Until then, I will just make sure that my wood walls are properly designed, installed, and tied down and spend my savings on my roof. I know you will never agree with me, and that doesn’t bother me, and I am not saying your product is inferior, it just seems to me to be overpriced for the benefit. Other people may disagree, which is their right and I am not trying to discourage that. It just seems to me that a lot of the argument for this is a fear tactic that your family will die if they don’t use this product, which simply is not the whole picture. You have to consider the house as a whole unit, and a chain is only as strong as its weakest link. Reinforcing the wall link that doesn’t fail as often to excessive levels just doesn’t make as much sense to me as reinforcing it to acceptable levels and then concentrating on the other links.
ICFconstruction
| 15 Jan 2009 03:10 PM |
Where do these houses get built, because I have not seen them? "house built with with a properly installed 2*6 wall, including typical corner bracing and with plywood double diaphragm". Urethane foam that house and it would cost the same as and ICF house and be less energy efficient, weaker, more sound transmission and could still rot or mold.
"how much money is that really worth" ICFs are easily worth the 3-5% more than a wood framed house built to the minimum code. And for even money an ICF house is worth more than the one you describe.
The most common place a roof fails, after the shingles or roofing, is at the connection. It is not magic, the stronger the walls/connection the higher winds the roof structure will withstand. And when a roof goes and the walls stay little or the debris falls inside. Furthermore if the roof does go first, the walls a considerably weaker and will likely collapse and that is more likely when people get hurt.
"Design a version of an ICF that can be adapted for roof use, and then you will be talking" Done! Lite-Deck, Insul-Deck and AmDeck. Check out the thread "Subject: Another example concrete hip roof!"
It is not that I am focused on a fear tactic, but the strength, or lack there of, is the point you are working on. And if you want to debate one, or all, of the other ways wood structures are inferior, we can do that.
boettg33
| 16 Jan 2009 08:21 AM |
Someone commented earlier that they would be dead in 20-30 years. Way to think about the bigger picture. You want to be green, but just green for yourself. This is one of the problems in the US. We build our houses for our immediate needs. Not for long term sustainability. This is an area that Europe does a much better job than us. When they build homes, they build them to last centuries, not 20-30 years. Think outside the box.
My house is over 150 years old and half of it is built with granite. Stone... longevity, locally harvested, environmentally friendly, strong. You get the idea. Of course, that is mixed with wood, but I did not build the original house. We need to start looking at houses that will last 100 to 200 or more years. Houses that can be easily remodeled internally to meet the changing times, but stand strong on the outside. Stone is one of those materials. Can every house be built with stone. No.
So what is an alternative? ICF is one alternative. Not the only, but currently one of the best. An ICF can be built to last 100-200+ years. The interior can be easily modified from generation to generation to meet their needs. Yet the external structure stands strong. Yes they cost more to build. I get that. Stop whining. You will easily recoup that cost in your energy savings over a 5-10 year period. Easily over your 20-30 year short sighted life.
Stop talking about sustainability and green only when it's convenient to you. If you can't stop thinking about yourself, then take your hypocritical self elsewhere.
Jason |
ICFconstruction
| 16 Jan 2009 09:20 AM |
Actually if you have a mortgage on your ICF house, you immediately recoup the the extra 3-5%. Because it is spread out into a monthly expense, as your utilities are a monthly expense. And your mortgage will stay the same 3-5% more a month and in the years to come the utilities will go up, maybe a lot. |
gregj
| 16 Jan 2009 10:39 AM |
Jason, have you checked your home for radon and radioactivity? Most granite has low enough radioactivity that it is safe for useage such as countertops but if your house is half granite it would behoove you to check it out.
And why get into name calling and telling people not to participate in this thread because you might disagree with what they said? I thought we were having a nice friendly debate/discussion here. Let's keep it that way. |
PanelCrafters
| 16 Jan 2009 12:04 PM |
Posted By boettg33 on 01/16/2009 8:21 AM ...Yes they cost more to build. I get that. Stop whining. You will easily recoup that cost in your energy savings over a 5-10 year period. Easily over your 20-30 year short sighted life. Compared to what?
Stop talking about sustainability and green only when it's convenient to you. If you can't stop thinking about yourself, then take your hypocritical self elsewhere. Wow...
aardvarcus
| 16 Jan 2009 01:02 PM |
Where do these houses get built, because I have not seen them? I'm living in one, and know several people who own them. I am unsure of in your area. Maybe you should be asking why the wood framed homes in your area aren't being built like that.
"house built with with a properly installed 2*6 wall, including typical corner bracing and with plywood double diaphragm". Urethane foam that house and it would cost the same as and ICF house and be less energy efficient, weaker, more sound transmission and could still rot or mold. Who said I was going to urathane foam it? I prefer using taped foam board sheathing over the outer plywood and fiberglass batts, and can achieve equal or better R value. As far as weaker, how much force would it take to pull a 2*6 in two? The reason for the weakness in a "typical" wood framed wall is the typical toe nailed joints, which are eliminated by the metal ties and the double diaphram. Doing these simple inexpensive fixes has already made my wall ten times or more stronger than minimum code. Why upgrade it again? As far as rot/mold goes, a proper drainage plane on my foam boards will eliminate that problem.
"how much money is that really worth" ICFs are easily worth the 3-5% more than a wood framed house built to the minimum code. And for even money an ICF house is worth more than the one you describe. On a $400,000 home, that 3-5% is going to be an extra $12,000-20,000 just for the walls. There is no way a couple sheets of plywood and some metal brackets cost anywhere near that much. So, you can forget "even money". As far as "worth" goes, your home is not going to be worth the extra 3-5% on the open market, as most homeowners care more about the bathroom vanity than the walls.
The most common place a roof fails, after the shingles or roofing, is at the connection. Thats why in my example I specifically stated both walls would have the same connection.
It is not magic, the stronger the walls/connection the higher winds the roof structure will withstand. That is why I said the same connection, so we can compare apples to apples.
And when a roof goes and the walls stay little or the debris falls inside. When a roof collapses, debris will get inside. Do you expect me to believe after a tornado, homeowners team up and go and drag a bunch of crap inside their wrecked homes before the news cameras get there, to make it look worse? I have seen many pictures of houses with roofs ripped off and the walls still there, with a bunch of debris inside. (Funny to note they were "minumum code" wood framed walls that stayed behind. )
Furthermore if the roof does go first, the walls a considerably weaker and will likely collapse and that is more likely when people get hurt. I think people would be getting hurt or swept away when the roof came off.
"Design a version of an ICF that can be adapted for roof use, and then you will be talking" Done! Lite-Deck, Insul-Deck and AmDeck. Check out the thread "Subject: Another example concrete hip roof!" Yes, I know of these products, but in your first post you specifically stated to use SIP's for the roof, so I assumed you didn't care for these products.
It is not that I am focused on a fear tactic, but the strength, or lack there of, is the point you are working on. Where did I say properly installed reinforced concrete isn't strong? I have just said I don't feel that you need to invest in a part that is already strong enough, but invest in one of the weaker links.
And if you want to debate one, or all, of the other ways wood structures are inferior, we can do that. And if you wish to debate all the ways a ICF is inferior to a 1' thick solid titanium wall, we can do that as well. I am looking at the added cost to added benifit ratio.
ICFconstruction
| 16 Jan 2009 02:01 PM |
I would challenge that the majority of wood framed houses in your area are not built the way you describe. And I would never encourage someone to build any wood framed home anywhere. I have seen too many, thousands, with problems that would have been prevented or minimized if they were ICF.
Mold does not happen just from leakage and drainage plain issues. Although if one thing on that exterior is missed, done wrong or not maintained, it will leak and cause damage. With ICFs all the fallible wraps, drainage planes, blah blah is not needed. An equally significant cause of mold, at least in cold climates, is condensation. One cause of which is a vapor barrier on the cold side of insulation, such as "taped foam board sheathing over the outer plywood". Actually mold remediation caused by condensation is much worse because it occurs deeper in the wall.
I agree; many ignorant homeowners would sooner spend the money on a granite counter-top or hardwood floors, than on the structure of there home. But unless they pay cash for the house, an ICF house does not cost them 3-5% more a month.
There cannot be the same or comparable connection in a weak wood wall as a concrete wall. Apples and oranges.
Roofs don't collapse from windstorms, they are torn off and the majority of the debris ends up outside the house, if not a long way away.
Wood framing is not strong enough. And if you tried to make one as energy efficient and as strong as ICFs it would cost more long before you achieved it. A few percent is hardly cost prohibitive. Titanium is a ridiculous comparison, but it helps show that there currently exists no better method of construction than ICFs.
aardvarcus
| 16 Jan 2009 02:24 PM |
Posted By ICFconstruction on 01/16/2009 2:01 PM I would challenge that the majority of wood framed houses in your area are not built the way you describe. And I would never encourage someone to build any wood framed home anywhere. I have seen too many, thousands, with problems that would have been prevented or minimized if they were ICF. I would challenge that most of the houses in your area aren't ICF's. What does that have to do with anything? You also fail to mention the problems could have also been corrected by the builder just building it right.
Mold does not happen just from leakage and drainage plain issues. Although if one thing on that exterior is missed, done wrong or not maintained, it will leak and cause damage. With ICFs all the fallible wraps, drainage planes, blah blah is not needed. An equally significant cause of mold, at least in cold climates, is condensation. One cause of which is a vapor barrier on the cold side of insulation, such as "taped foam board sheathing over the outer plywood". Actually mold remediation caused by condensation is much worse because it occurs deeper in the wall. That would be true, but I don't live in a cooling dominated climate. A correctly designed wood wall will not have these problems.
I agree; many ignorant homeowners would sooner spend the money on a granite counter-top or hardwood floors, than on the structure of there home. But unless they pay cash for the house, an ICF house does not cost them 3-5% more a month. 3-5% is an underestimate, based of my local market. It could be different where you live. You forget, there are other insualtion systems that can save you money.
There cannot be the same or comparable connection in a weak wood wall as a concrete wall. Apples and oranges. Why not? There is nothing magical about either wall.
Roofs don't collapse from windstorms, they are torn off and the majority of the debris ends up outside the house, if not a long way away. Where does the debris a long way away end up? In someone elses house.
Wood framing is not strong enough. And if you tried to make one as energy efficient and as strong as ICFs it would cost more long before you achieved it. A few percent is hardly cost prohibitive. Titanium is a ridiculous comparison, but it helps show that there currently exists no better method of construction than ICFs. No, it would not cost more. 20,000 is actually very cost prohibitive for most people. Yes titanium is reduculous, which drives home the point in there is no reson to upgrade something that is already strong enough.
I hope I am not making you upset, I am just trying to help.
Donnerwetter
aard - yep, I sure did see some of those houses you have described (along with a few thousand other wood constructed buildings) - in fall of 2007 from Pepperdine University all the way to San Diego, California - burn totally to the ground in less than 20 minutes!!! Also saw a few ICF buildings - also in the direct path of these wild-fires - which had little or no damage...HMMMM Maybe fire has not been invented yet in your neck of the woods!
Mother nature provides encore presentations each and every year (in case you missed it) as to why wood (for exterior walls) might be too "Hot" of an idea!!!!! |
ICFconstruction
| 16 Jan 2009 02:43 PM |
Fire, windstorm, mold, energy waste, air infiltration, noise, deterioration, fallibility during construction all mitigated with ICFs. Check out this photo http://apachecreekbuilders.com/katrina.htm
There is a reason why the rest of the world builds with concrete and masonry, it's better.
$15 -$20 thousand is hardly cost prohibitive on a $400,000 house. They should just build a $385,000 house.
gregj
ICFconstruction
| 16 Jan 2009 03:21 PM |
I did not suggest ICFs solved all water leaks or problems, just most. However the use of them is less fallible. For instance you of course still need water proofing below grade.
Of the 10 examples Greg gave:
4 are problems with below grade water-proofing. (Wood foundations are horrible) 2 are roof leaks and have nothing to do with ICFs, other than that is what the walls are. 2 were under construction. (look what happens to wood components exposed to the weather during construction) 1 was a composite ICF, post and beam. That I will read further.
The remaining 1 involved openings that appear not to have been sealed, peel and stick should be used around windows and doors. (A similar leak in a wood framed would undoubtedly would result in much more severe damage)
JTWelsh
| 18 Jan 2009 06:54 PM |
This is my first post on this site, I just had to get a word in on this conversation.
It was said that $20,000 extra on a house would be cost prohibitive, and yes to a "normal" family it would be.
But the $20,000 reference came from building a $400,000 dollar house versus a $420,000 - and I'm sorry if somebody is of the financial ability to build a $400,000 house, then an extra $20,000 ISN'T going to break the piggy bank.
First of all, spread out over the typical 25 year mortgage, that $20,000 extra cost equates to roughly $70 dollars a month. I'm sorry, but if $70 a month is keeping you from building a $420,000 house, maybe you should be thinking a little smaller anyway.
And of all the new homes that are being constructed these days, how many of them are being built "properly"? HAHAHA If you think that 2x4's and aspenite (chip board) are proper then do I have a deal for you on some magic beans.
Nudura Sales Rep - Bird Stairs St. John's, Newfoundland Canada T: 709-747-0040 |
boettg33
| 18 Jan 2009 07:44 PM |
Interesting, I didn't see any name calling in my post. What I did was call someone out for being short sighted. I finish the post by saying people love to talk about being green or sustainability. As soon as it's not convenient, many give up and take the easy route.
I am not saying we need to totally abandon stick frame construction. What I am saying is that we cannot think about houses that are only going to last 20-30 years. Or even 50-60 years. The current methodologies used in stick-frame construction do not support longevity. I do realize there is no one answer. I do believe that ICF done right is a construction technique that can be long term/sustainable. One of the problems with ICF right now is that there are not enough builders that are properly trained at this time.
I also agree with you about checking for radon with granite. Radioactivity is a new one I had not heard.
Jason
ICFconstruction
| 19 Jan 2009 07:38 AM |
You are right, the wood framed houses they are building are disposable houses. I also agree with your statement,"I am not saying we need to totally abandon stick frame construction" stick framing is suitable for interior walls. |
| Topic is locked |
399 |
399 |
