Faulty Earthlinked DX systems
Last Post 07 Jul 2011 10:29 AM by drao. 212 Replies.
Page 9 of 11 << < 7891011 > >>
JackHUser is Offline
07 Oct 2009 06:49 PM
This is the one that we always thought had a ductwork issue.
High limit as "engineer" pointed out, can lead to short cycling like that, ...AKA, duct work to small, dirty filter, wrong air volume.
Also what kind of thermostats do you have?
Maybe Brian should put a regular PSC motor back in that one, to test against the ECM, just a thought. or keep the front door off the furnace to see what happens to short cycle.
This all goes back to," bad duct work can kill a heat pump",but it can also " kill a furnace"!
geo fanUser is Offline
07 Oct 2009 07:02 PM
Ill jump in here , If the burners are on for LESS then 1 min my first thought would be stat . only because for a high limit to trip in that short amount of time the fan would have to be locked up . but the question is . Does it shut off while the stat is calling . or is the system short cycling because thats what its being told to do .
07 Oct 2009 08:08 PM
That could well be the case. I have nearly zero experience with gas home furnaces. (Gas units I deal with make 30,000 lb / hr or more steam - controls are a BIT different...)
Adding support to Geo Fan's stat theory is the short cycling of the 4 ton geo unit a page or so back in similar weather - cycles of 3-5 minutes by a geo unit could easily equate to 1 minute cycles by gas heat.
Perhaps the stat is a bit too sensitive or is improperly located near a supply
07 Oct 2009 11:07 PM
Posted By geo fan on 10/07/2009 7:02 PM
Welcome back GF, missed ya!
If the duct work were causing the short cycle folks, wouldn't it have done it pre-geo?
j
draoUser is Offline
08 Oct 2009 08:27 AM
Thank you for the input.  My guess is also that it is a thermostat issue.  Brian replaced all my previous thermostats with some state of the art Honeywell ones.  I have to find out the model.  This did not happen with my gas furnace previously.     Hence it cannot be a duct problem. My electricity use with no 4Ton unit on is also higher than normal probably because of the airhandlers coming on frequently. He is coming today to check it out.
Here are the reads.
10/04/09
00139        06
2132            24
 4898          05
4155              64
           High   57F
10/05/09
00143        04
2159            27
 4900          02
4226               71
           High   57F
10/06/09
At 3PM , 4 Ton
Switched off and system set to Emergency Gas Mode
00149        06
2184            25
 4904          04
4296              70
           High   61F
10/07/09
 00155        06
2184            00
 4905           01
4339               43
           High   57F
08 Oct 2009 08:36 AM
That is why I questioned the thermostat. If there is a cycle rate per hour or a heat pump/gas heat switch on the back, in the wrong position.
Or it could be as simple as, debris in the drain line, causing a backup of condensate from the furnace to shut the flame off. but if the furnace is completely shuting off after flame goes out, its probably not.
draoUser is Offline
08 Oct 2009 08:43 AM
Thanks for the quick response.  I will have Brian look into these pointers when he gets here .
MasoudUser is Offline
08 Oct 2009 10:10 AM
"This did not happen with my gas furnace previously. Hence it cannot be a duct problem." The ducts are the same, but there are new ECM motors pushing air through them.
Regards,
Masoud
draoUser is Offline
08 Oct 2009 03:35 PM
I am told that the Honeywell thermostats are Model : TH6320R1004 with wireless capability.  To Mr. Masoud, I am not sure I understand the drift of the new ECM motors causing short cycling.  Please elaborate.  Thanks.  Brian was here this morning and checked things out.  He thinks it may be something to do with the cycling rate of the basement thermostat.  He will get in touch with their tech dept. and will have an update when he comes next week with the meters and temp sensors to monitor system run times .
08 Oct 2009 05:15 PM
My point was that air handlers and ducts are two major components of the air distribution system and work together. Changing one, could have changed the equation, resulting in wrong air volume that was brought up by JackH at the top of this page.
Regards,
Masoud
draoUser is Offline
15 Oct 2009 10:17 AM
Here are the past week's meter reads.  Brian will be here tomorrow with the run time meters and temp sensors .  He also has a call into Honeywell for adjusting thermostat sensitivity.  My 4 Ton unit is still off and system is on emergency gas mode.
                                           2Ton                          4 Ton                            5Ton                                 Main
10/08/09
 00162        07
2184            00
 4911           06
4384               45
           High  61F
10/09/09
 00168        06
2184            00
 4911           00
4425               41
            High  52F
10/10/09
 00176        08
2184            00
 4920           09
4475               50
            High  52F
10/11/09
 00186        10
2184            00
 4932           12
4535               60
            High 43F
10/12/09
 00199        13
2184            00
 4944           12
4598               63
            High  50F
10/13/09
 00208        09
2184            00
 4952           08
4649               51
            High  49F
10/14/09
 00221        13
2184           00
 4968           16
4718                69
           High   46F
Please let me know if the 2Ton and 5Ton systems are operating as they should with the current temps.  Thanks again!
Bill NeukranzUser is Offline
15 Oct 2009 12:11 PM
There may be a faster way to determining if your system(s) are indeed not performing.
My recommendation is to ask your HVAC professional that's coming tomorrow to include in his measurements whatever's necessary to:
1. compute COP
2. enable look up of manufacturer's COP spec (it will vary as a function of various parameters that may need to be additionally measured).
Then, ask him to do the COP computation, look up what the spec is for the conditions of measurement, and simply tell you if the computed COP is at or below manufacturer spec.  And do this for each unit.
This is a straight forward exercise with a water-to-air GSHP.  What I don't know is how difficult this is with refrigerant-to-air (DX) technology systems.
If COP can be measured here, then it's going to give you a 'figure of merit' for the complete system - the refrigerant piping, the compressor pumping, and GSHP unit itself, that can be compared to 'good' versus 'not good.'
The reason I offer these comments is because, 9 or so pages into this thread, after a lot of expense on the part of the HVAC installer, and after a lot of aggravation / cost to the owner, still, it's very uncertain if it's the equipment or the house (including the duct system).
Hence, the suggestion here is thought to assist with at least getting quickly to the decision point of 'it's the house' or 'it's the equipment.'
Good luck.
17 Oct 2009 09:41 AM
Thanks Curt,   I am anxious to try these out.
draoUser is Offline
10 Nov 2009 11:29 AM
Hi everyone,
                         I haven't been updating recently since there was not much to update.  Brian had to order the meters from another state and they took their time.  He is in the process of putting them in.  Hopefully, he will get it done today.  I briefly turned on the 4Ton unit(on 10/17/09 and 10/18/09) and the energy drain happened immediately.  I turned it off as in the table after talking to Brian. Both my basement and upstairs zones are on gas heat presently.  I just got my Oct 09 bill and I noted this from the bill.
Last year at the same time, I had complete geothermal heat.   Here's some data , temperature maintained 72F
Last year gas usage/day (cooking and hot water only)  : 0.248MCF
This year gas usage/day(cooking, hot water and heating basement and upstairs-4t unit area):  0.397MCF
In other words, the gas consumption for heating the area of the 4Ton unit(upstairs and basement)/day is : 0.397-0.248=0.149MCF
For 30 daysi.e. a month it is 0.1249*30= 4.47MCF=$45.14 in heating costs.($10.098/MCF)
From the statistics provided to me by Brian, this unit, in October was supposed to consume 332.6kwh translating to about $30 in heating costs.
If you observe the fact that the 4Ton unit consumed 37kwh in just one day with moderate temps, that would amount to 1110 kwh for 30 days or $100!(conservative estimate!).  Even the 5Ton unit uses less!!
So, people is it wrong for me to assert that this unit is a piece of JUNK!
The only hole I see is the MONEY PIT!
Please offer me your well meaning comments.
Thanks!
drao
                                              2T                              4T                                 5T                                   Main
10/15/09
 00235        14
2184           00
 4989           21
4789                 71
            High  45F
10/16/09
 No reads taken
 No reads taken
No reads taken
No reads taken
           High   46F
10/17/09
4 Ton started back at noon with modified
Cycle times on stats
 00262         00
2190            06
System worked
Only 6 hrs before reading
 5021           32
4936            147
            High  47F
10/18/09
Turned off 4 Ton at 8PM after talking to Brian
 00275         13
 2227           37
 5045           24
5050              114
           High   50F
10/19/09
 00287          12
 2230           03
 5048           03
5100                 50
            High  60F
10/20/09
 00292          06
 2230           00
 5048          00
5136                 36
            High  62F
10/21/09
Brian turned on   4 Ton unit to check performance for 30 mins
 00294         02
2231           01
 5048           00
5166                30
            High  67F
10/22/09
 00297        03
2231           00
 5048           00
5195                 29
           High  59F
10/23/09
 00309        12
2231           00
 5053           05
5251                 56
            High  60F
10/24/09
 00316        07
2231           00
 5054           01
5288                37
           High   54F
10/25/09
 00325       09
2231           00
 5062           08
5343                55
           High   58F
10/26/09
00333         08
2231           00
5062           00
5380                37
          High    61F
10/27/09
00338         05
2231           00
5062            00
 5413               33
      High        55F
10/28/09
00344         06
2231           00
5062           00
 5447               34
       High      54F
10/29/09
00350         06
2231           00
5062          00
 5489               42
        High     55F
10/30/09
00357         07
 2231          00
5064         02
 5526              37
         High   70F
10/31/09
00361        04
  2231        00
5064           00
  5560            34
         High    61F
11/01/09
00370        09
  2231        00
5072           08
  5610            50
          High   48F
11/02/09
00383        13
  2231        00
5080           08
  5664            54
           High  49F
11/03/09
00395        12
  2231        00
5089           09
  5718            54
           High  47F
11/04/09
00409        14
  2231        00
5101           12
  5779            61
          High   45F
11/05/09
00421        12
  2231        00
5112            11
  5834             55
            High  47F
11/06/09
00437        16
  2231       00
5125            13
  5899             65
            High  48F
11/07/09
  No Reads
  No Reads
No Reads
  No Reads
             High 66F
11/08/09
00452         15
  2231        00
5132            07
  5984             85
            High  69F
11/09/09
00454         02
  2231       00
5132            00
  6014             30
             High 65F
draoUser is Offline
11 Nov 2009 12:41 PM
Just an update.  The meters have been installed by Brian today and I am going to switch  to complete geothermal this evening after reads are taken- for a 24 hr period so run times may be obtained. Brian turned on the 4Ton unit temporarily to check meters installed correctly.   Tomorrow at the same time, I will switch 4Ton unit off and go back to gas heat so as to stem the energy hemorrhage. I will post data when I have it.
draoUser is Offline
25 Nov 2009 11:36 AM
Just an update.  I have sent run time info with 4TON EARTHLINKED DX UNIT for 24 hrs and then switched the same to NATURAL GAS MODE FOR THE SAME AMOUNT OF TIME to Brian.  He is currently in the process of crunching numbers and will get back to me with the result which I will post promptly.  Please check for updates.  " THE TRUTH OF THE PUDDING(PUMPKIN PIE) IS IN THE EATING OF IT.  ALSO, THE GOOSE (TURKEY) IS FINALLY COOKED! HAPPY THANKSGIVING!
soxsterUser is Offline
14 Dec 2009 11:40 AM
Did this finally get resolved?? I am looking at a Earthlinked DX system in southern Missouri (5 ton), and hearing cases like this, obviously gives me pause/hesitation, before jumping onto the geothermal bandwagon. I hope Earthlink reps are paying attention for future sales potential. I do not want to buy into a system that is not consumer responsive to problems with their equipment. thanks
southlineUser is Offline
16 Dec 2009 10:09 PM
Well.....? What happend next?
20 Dec 2009 06:03 PM
I guess this got resolved I see no further gripping here.
20 Dec 2009 08:31 PM
Posted By soxster on 12/20/2009 6:03 PM
Sounds like a leap of faith to me.
People Online People Online: Visitors Visitors: 126 Members Members: 0 Total Total: 126
